JenD1988
Apr 24, 2019Tutor
Extender won't reset or connect a solid green light
I had to move my extender from one outlet to another & now it won't work. The auburn light comes on then it just constantly blinks green, never goes solid. It won't reconnect to my router wps, i tr...
Apr 24, 2019Guru - Experienced User
Check the user manual to see the LED behaviors.
The unit probably needs to be replaced.
