JenD1988
Apr 24, 2019Tutor
Extender won't reset or connect a solid green light
I had to move my extender from one outlet to another & now it won't work. The auburn light comes on then it just constantly blinks green, never goes solid. It won't reconnect to my router wps, i tr...
JenD1988
Apr 26, 2019Tutor
yes the power led would not light solid green, auburn when first plugged in then constant blinking green. I tried every reset possible, could not see the name, could not access the mywifiext website.....I have since talked to a netgear rep & they have replaced my unit after repeating all the resets & still no solid green light. Thank you.
Christian_R
Apr 26, 2019NETGEAR Employee Retired
Hello JenD1988 - Are you able hard wire the extender to a PC or laptop using the ethernet port? What is the LED status of the link rate indicator?
~Christian
