ServerMax90
Mar 22, 2020Aspirant
Extenders EX7500
Good Morning If not possible tto connect each extender to the router is right to connect the second extender to the first one. I bought them after watching that feature on your Mesh extenders webp...
ServerMax90
Mar 23, 2020Aspirant
So basically Netgear shouldn't label those devices as "Mesh" if canno't do what 802.11s describes :/
Don't you agree?
Mar 23, 2020Guru - Experienced User
No I don't agree.
Its a "mesh extender" not a fully mesh system.
and extenders aren't recommended past 1 extender regardless of if you run mesh or standard
- ServerMax90Mar 24, 2020Aspirant
So it should be able to do what 802.11s describe https://www.academia.edu/21587927/IEEE_802.11s_The_WLAN_Mesh_Standard
Let me remember you that your advertising page is showing a daisy chain for yor EX extendershttps://www.netgear.it/landings/mesh-wifi-extenders/
Your product shouldn't labeled "mesh"
Mesh networks (BT/wifi/proprietary) work differently.
Best regards- plemansMar 24, 2020Guru - Experienced User
1. this isn't netgear. this is the public community forum. In no way shape or form am I netgear so saying "your advertising" or "your product" doesn't mean a thing to me. And we're not paid to do this.
2. I'm not going to argue with you. I've explained how to make it function better. you can use it in one big mesh but if the router signal isn't stable, you'll probably have issues. Maybe there is improvements in running multiple extenders in the pipeline. Again, not netgear here.
Good luck .
- ServerMax90Mar 26, 2020Aspirant
There is nothing to argue.
Is it capable of 802.11s?
Yes---> "Mesh wifi"
No--->Not "Mesh wifi"
Easy!
For me, labelling "Mesh wifi" a thing that isn't Mesh is not correct cause mesh is an IEEE standard.
I thought "community Netgear" was managed by Netgear, and answers come from people paid from Netgear. Sorry.
