alcat
Mar 09, 2018Luminary
Extenders vs Mesh
Hello I am looking for clarifiction on Extenders vs Mesh, specifically when the extenders are sharing the same SSID (I am using a Nighthawk X6S EX8000 and planning on extending this configuratio...
- Mar 09, 2018
Thanks for the speedy reply. To summarise, mesh is more than a shared SSID. Mesh has additopnal technologies to make the hand off between satellites more effcient than traditional router/extenders.
Are there any good white papers you can recommend? In or outside of Netgear?
thanks!
jvasanth1984
Mar 09, 2018Virtuoso
Hi alcat,
This extender have Mesh option which can be utilized by enabling one wifi name where devices can seamlessly roam between router and extender network not just by having same SSID, but it does support 802.11k which will help in seamless roaming for any device that support this protocol. Adding to that, it does have a smart connect which can be enabled only if it is enabled on your router too that way devices that support both 2.4 and 5GHz bands can switch between these bands based on signal effeciency which is called as band steering. Let me know if you need anymore information so that I can provide it.
- alcatMar 09, 2018Luminary
thanks!
- jvasanth1984Mar 09, 2018Virtuoso
Hi alcat,
This link can give you a detailed information on wireless https://www.cwnp.com/uploads/802-11_rsn_ft.pdf.
- alcatMar 10, 2018Luminary
thanks for the white paper and replies.
I decided to go with adding an additional extender (using same SSID) vs replacing with a Mesh network.
thanks again
