dorr
Jul 02, 2019Tutor
Extending 2G and 5G signals
Hello. Is there some way on NetGear's product page to filter extenders that include 5g? I currently have the N300, which only does 2.4 GHz, and I know that this model does not support 5g. I wish to p...
- Jul 02, 2019
With the size of your house a decent gigabit wireless AC router should cover it. This is contingent on a lot of factors. HVAC, foil backed insulation, brick/concrete do a great job of blocking wifi signals so you have to take that into account a bit. Plus you'll see a much better processor in them when you jump from a n300 router to a gigabit wireless ac router.
dorr
Jul 02, 2019Tutor
Thanks for the quick reply. My home is roughly 1200 sq ft, raised bungalow.
Jul 02, 2019Guru - Experienced User
