floridaphoto's avatar
floridaphoto
Follower
Jul 20, 2016
Extending a Comcast system
I need to extend the wifi in a 2 story home using a Comcast Technicolor TC8305C gateway. Getting spotty signal on one side of second floor. Gateway is on 1st floor. Will a N300 EX2700 work in this situation? Can I set the SSID and PW the same to make roaming around the house with a mobil as smooth as possible?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello floridaphoto
    Yes this should work for you and yes you can set the SSID and password the same.
    DarrenM
