RUBENSOLO
May 07, 2016Aspirant
extending internet connection via wired ethernet cable
Hello, FIrst time poster. I have a netgear R8000 Nighthawk on my 2nd floor. I am planning to use an ethernet cable connected to the R8000 and take it downstairs to my living room. My question is, is...
- May 07, 2016
Thank you very much!
RUBENSOLO
Thanks for the reply. I read page 18 and my understanding is that as an access point it wouldn't allow me to connect to other devices using a wired connection just wirelessly
Note: In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection.
Not sure if my internet provider be able to install an Ethernet switch for me. Would it require just a single connection from the main router downstairs? Could the Ethernet switch be use to connect multiple devices?
thanks
TheEther
May 07, 2016Guru
I never noticed that restriction. I'm quite surprised that it exists. That makes the EX7000 less flexible. A shame.
You should not need any help from your Internet provider. You can get any Gigabit Ethernet switch (e.g. Netgear's GS205v2). Like I said before, you can plug all of your devices in the living room into it. You only need a single connection from the switch back to the main router.
- RUBENSOLOMay 07, 2016Aspirant
That's perfect and a cheaper solution than buying the EX7000. Is there a significant difference between the FS and GS range?
Is there also a possible drop in performance when using an ethernet switch?
thanks
