EllDee71
Jun 24, 2025Aspirant
Extending Mesh
I have a NetGear Nighthawk MR60 mesh wifi router with 2 satelites , it is performing quite well. I am now building a detached garage approximately 50 feet from my house. I alos have an EV and ...
CrimpOn
Jun 24, 2025Guru - Experienced User
EllDee71 wrote:now building a detached garage approximately 50 feet from my house
Does the garage have an electrical water connection to the house? (thinking that construction of a new structure would be an ideal time to bury a 1" PVC conduit to allow installation of a network cable.)
The generally accepted methods of extending service to a building are:
- If within 300 ft. installing an Ethernet cable is the optimal solution. Best performance. Least complexity. Often impractical.
- If there is an electrical connection between the main building the new building, Powerline can often provide a good connection.
- A "wireless" bridge will often provide adequate service. Since these units are rated in terms of Kilometers, over a short distance they can often penetrate both the main and remote building walls and still get good performance.
The biggest question is
- Do you want WiFi in the garage that is networked to the primary network, or
- Do you want to extend the seamless mesh WiFi system to the garage? In that case, only another MS60 satellite will do what you want.
I would start by purchasing an MS60 satellite from Amazon. If it will connect with the main house, "problem solved". If not, return it to Amazon and confront the issue of what performance is necessary. For example, a WiFi extender will connect to the primary WiFi network over 2.4G at a greater distance than an MS60 satellite with 5G WiFi. If the primary goal is to connect the Chargepoint to the network, that might do it. WiFi extenders are relatively inexpensive.
- EllDee71Jul 02, 2025Aspirant
Thank you CrimpOn. This seems like a good plan. The large metal garage door that faces the house goes up next week. At that point I will do the test with the satellite, but I am thinking to use one of my current units for the test.
Just fyi I do have a pipe from house to garage to carry electric. However the building inspector doesn't allow electric & Ethernet in same tube, it would cost ~$2k to place an additional tube.
Thanks again, LD
- FURRYe38Jul 02, 2025Guru - Experienced User
Something you could review and check into. Some power line adapters. Depnds if power is on same circuit though.
Thank you FURRY. I hope to get the grage door on soon and make a test. Will definitely try Powerline if mesh satellite does not work
- CrimpOnJul 02, 2025Guru - Experienced User
It is important that the WiFi signal between house and garage not pass through the metal garage door. Any WiFi signal (mesh WiFi, WiFi extender, wireless bridge, etc.) is affected by passing through metal. There are usually areas to the side of or above a garage door that might be suitable.
This is absolutely correct.
