EllDee71
Jun 24, 2025Aspirant
Extending Mesh
I have a NetGear Nighthawk MR60 mesh wifi router with 2 satelites , it is performing quite well. I am now building a detached garage approximately 50 feet from my house. I alos have an EV and ...
EllDee71
Jul 02, 2025Aspirant
Thank you CrimpOn. This seems like a good plan. The large metal garage door that faces the house goes up next week. At that point I will do the test with the satellite, but I am thinking to use one of my current units for the test.
Just fyi I do have a pipe from house to garage to carry electric. However the building inspector doesn't allow electric & Ethernet in same tube, it would cost ~$2k to place an additional tube.
Thanks again, LD
Jul 02, 2025Guru - Experienced User
Something you could review and check into. Some power line adapters. Depnds if power is on same circuit though.
- EllDee71Jul 02, 2025Aspirant
Thank you FURRY. I hope to get the grage door on soon and make a test. Will definitely try Powerline if mesh satellite does not work
