BDFlora59
Mar 27, 2019Aspirant
Extending my C3000 router
Hello,
I have the Netgear C3000 router and I want to extend my range so that I have continuous service to my devices that are just outside my home in the backyard patio. Will the NETGEAR Nighth...
- Mar 27, 2019
Thanks for the info! I already have a plug-in extender and it gives intermittent service, but I like the idea of going for the Nighthawk and upgrading my C3000 later. I appreciate your help!
Mar 27, 2019Guru - Experienced User
It will however the speeds on the EX7500 are far greater than whas on the C3000. So you'll have some growth for future proofing should you decide to upgrade the C300 to something newer.
Or you could keep with something that matches the C3000:
https://www.netgear.com/home/products/networking/wifi-range-extenders/WN3000RP.aspx
