Mancaver's avatar
Mancaver
Extending my Verizon Router
Here is my scenario. I wish to extend access out to my Mancave, This has to be wireless.
My thoughts are as follows
Current setup is Verizon Router 9100EM is my main connec tion to the world.
I just installed a Rangemax N150 (WPN824N) to the other side of the house (WIRED) I can connect wireless now through that with a good signal .
Now inside the Mancave which I wish to add a WNHDE111 needs to be wireless to the WPN824N. This is because the signal fades on my laptop when I shut the door at the mancave.
So the question is this possible?
Recap
Verizon 9100EM FIOS to the Street
WPN824N wired to 9100EM with Wireless access now
Add WNHDE111 wireless to WPN824N so that it will pass all the way back to Verizon.
  • Since I have the WHNDE111 Do you see a solution I can put it to in the home?
    A second AP attached to the Verizon router Hardwired?
    I will go get a WN2500RP for my mancave solution and link it wireless to the WPN824N.
    Will keep you posted once I get the 2500.
  • Retired_Member's avatar
    Retired_Member
    Replace man cave door with a curtain.:D
