xh28
May 09, 2024Guide
Extending out the wifi to the new Summer house. Nighthawk R7800 and X6S
I have the r7800 connected to the internet modem and then the X6S is in the garage connected via Wifi. I get really good speeds and really pleased. We have a new summer house and my plan is to c...
- May 10, 2024
If it was me? I'd scrap the current setup and switch to a mesh setup.
You'd have the router in the main house, a satellite in the garage, and a satellite in the summer house (hardwired to garage satellite). With the setup, devices would roam automatically.
You could simple add an access point in the summer house if you'd like
May 10, 2024Guru - Experienced User
xh28
May 12, 2024Guide
Sadly you are right but the budget does not allow this but I will work out my upgrade path as I can afford it.
Thanks for your help.
Tony
- plemansMay 13, 2024Guru - Experienced User
You might find a decent one used on fleabay/marketplace that would work fine. I'm a fan of the EX7500/EX7700/EX8000 for the AC systems. They're rock solid, fast, and have a dedicated backhaul for when in wireless extender mode and not access point mode. I've seen them pretty cheap used and they work well
- xh28May 13, 2024Guide
The EX8000 looks good. Found one on Ebay for £40 which is a lot cheaper than the mesh option and will probably do the job for what I want.
Tony
good luck!
Remember if you're hardwiring it in, to set it in access point mode.
Its a solid extender. I've used it both in extender and access point mode
