emmetb
May 11, 2022Initiate
Extending wifi to two outbuildings
I am in the UK and have a BT broadband connection and Smarthub (wireless/Ethernet ports) that gives good speeds. I want to extend the wireless network from this hub to two outbuildings. In preparatio...
- May 13, 2022
yes you can daisy chain. Some of the satellites have more than 1 ethernet jack. You'd just go router------>satellite------>satellite with ethernet. If you happened to have a satellite with only 1 ethernet, a simple unmanaged switch would work
emmetb
May 13, 2022Initiate
Thanks for the reply and that sounds like an option having done some reading up on your suggestion. What I am unsure about is how I would connect the devices. I'd need a 'parent' node in the house that would connect to the Smarthub and then two satellite nodes, one in the adjacent outbuilding and then another in the more distant outbuilding. I currently have a CAT6 cable between the two outbuildings in readiness for this and a Cat 6 cable from the adjacent outbuilding to the house. What I don't have (which would have been more sensible) is a cable from the furthest outbuilding to the house. So I sort of need to daisy chain the satellites... hub -> parent -> satellite 1 -> satellite 2 ... is that possible? Can I out some sort of 'splitter' in the first outbuilding to connect both satellites to the parent? Apologies if this is not making sense.
May 13, 2022Guru - Experienced User
- RadocMay 15, 2022Initiate
Apologies for piggy backing on your post, but I have an identical issue. Difference is that the walls of the buildings , being medieval, are around 2 - 3 feet thick! It comprises a church and two halls.
The current working setup with good strong internet provision (72 mbps) from BTInternet. That provides WiFi throughout nave, aisles and chancel. I have run an ethernet cable through to one hall . Because of distance it is via a 100 Metre cable to a hub then a 50 metre cable to hall. In the hall I have a Netgear AC1200. The cable connects to that and provides the WiFi in the hall. Again strong signal throughout. This was setup a few years ago and I can't recall if it was setup as a Hot Spot. or just simply an extender (I gather the AC1200 can't be connected this way so must be a Hot Spot).
I now want to extend to second hall, which is adjacent to church. WiFi doesn't penetrate the 3 foot thick walls so I have run a second ethernet cable (25 metres) to hall from switch.
I have a second AC1200 but that means setting up a second Hot Spot .
Is there a better way of doing this (at low cost - church has little money ),
Thanks, and again apology for piggy backing on OP.- plemansMay 15, 2022Guru - Experienced User
You could use another access point (most routers have an access point mode). You could even use the same ssid as the walls more than likely block the signal.
Or you could switch over to a renewed/refurbished mesh system. The benefit is, if they're hardwired, even a cheap dual band system would give you pretty good performance.
If you have further questions, please start your own thread and we're happy to help.
