AlanMoseley
Oct 10, 2011Aspirant
Extending Wireless Range with WG602v4
Hi there, hope someone can help. I have a DG834 ADSL router (not wireless) attached to a WG602v4 configured in Access Point mode, with a static IP address outside the DHCP scope, broadcasting the SSI...
jmizoguchi
Oct 12, 2011Virtuoso
setup looks fine to me. have you test with open network and see if the result is same over WEP?
also test with static IP on one of the wifi device and see if you are able to ping the router and/or public domain etc.
