chris_b1
Aug 10, 2015Aspirant
Extending Wireless Range
I am trying to extend the range of my network from an R6300 router, so dual band, 802.11ac 1300mbps capability, which I want to maintain thorughout the house. Unfortunately, the main AV equipment is ...
- Aug 11, 2015
Hi chris_b1
A possible solution is to connect a range extender like the EX3700 as an access point. The range extender would be in the dark spot you mentioned and it would be wired to your router.
You can also connect the range extender to your switch that has the powerline connection.Please review page 15 of 47 about access point: http://www.downloads.netgear.com/files/GDC/EX3700/EX3700_UM_8may2015.pdf
The other option is a powerline with WiFi such as the XWNB5221. Please do run a comparison between the products and see what fits your needs.
Let us know if you need further assistance.
Regards.
NhanN
nhann
Aug 11, 2015NETGEAR Employee Retired
Hi chris_b1
Regards.
NhanN
chris_b1
Aug 12, 2015Aspirant
NhanN
Thans - I will have a close look at those two. I was getting ready to go for a WAC120, but that is rather overkill for what I need, I suspect.
Chris
- chris_b1Aug 12, 2015Aspirant
NhanN
Many thanks. The EX3700 looks fine for my purposes and I have just ordered it. The XWNB5221 is less suitable, in part because I think it is not available in the UK(grr) and also because I think it is only 802.11n, while I would like to maintain 802.11ac coverage.
BTW, if you are Netgear employee, you might note that the UK website, in its comparison engine, shows the EX3700 as solely an 802.11n device, which is misleading.
Many thanks for your help.
Regards
Chris
- nhannAug 12, 2015NETGEAR Employee Retired
chris_b1
You're welcome! Glad you found an option.
Yes, you're right about the comparison. I'll pass it along to the web team.Thanks!
Regards,NhanN
