andreaboccotti
Nov 26, 2020Aspirant
Extension for Outdoor of my Netgear R8000 Nightahwk X6 needed
I do have a Netgear system to cover my flat, but now I need an extension to use it outdoor. Any suggestion ? Is the ORBI satellite works ? I plan to attach the the EX8000 Extension. Thank you...
andreaboccotti
Thanks !
Can I connect the EX8000 to the WBC502 with a cable ?
So the question basically is :
Can I exit with a cable from the EX8000 and plug into the WBC502 ?
thanks
Ciao
Andrea
Nov 26, 2020Guru - Experienced User
should be able to.
Only thing with the WBC502 is it uses POE to power it. You'd need to go
EX8000-----lan cable-----power injector-----WBC502.
