ahyland
Nov 13, 2020Tutor
Failed connection / "self-assigned IP address"
My EX 2700 worked for several weeks but will no lonter connect to my MacBook. When I go to System Preferenes, I get this message: Wi-Fi has the self-assigned IP address 169.254.54.132 and will n...
to factory reset push and hold the reset button while its powered on. hold for 7-15 seconds.
Then you can follow the install guide. The support site has 2 install videos. both wps and the installation assistant.
it also has written guides, manuals, and the firmware.
I'd recommend using the installation wizard.
https://www.netgear.com/support/product/EX2700.aspx
Many have modem/router combo devices. I'd take a look at the model number on the label
