randycamp's avatar
Mar 31, 2020
Failed to obtain IP address EX6250
I have installed an EX6250 and have a problem accessing an IP address on every wireless device in my house (2 cell phones, 2 laptops, and 1 Chromebook).   The initial connection seems to work, but ...
  • plemans's avatar
    Apr 01, 2020
    Check into your router and what issues it has with extenders. Not all routers work well with extenders or they need to set static addresses to extenders. The router is what's assigning ip addresses. the extender is just the go between.
    If its the router causing the issue, buying a different extender isn't going to fix the problem.
    what router are you using?
