JohnDe
Apr 18, 2020Guide
Fast Lane - doesn't make sense
Can anyone explain the advantages of Fast Lane because it doesn't make any sense to me? Either way you set it it amounts to 2.4GHz - either it's 5GHz from the router> 2.4GHz to the devices or 2.4GHz ...
Apr 19, 2020Guru - Experienced User
the reason why is that when your a single radio (wireless chip/band) is having to receive and then retransmit dat, it cuts the bandwidth in half and increases latency. Reason why is it can't do both at the same time.
If you set 1 of the chips just for router--extender communication (fastlane) that chip isn't receiving and then turning around and rebroadcasting. Its able to pass it directly to the other band/chip in close to real time. the decreases the bandwidth and latency hit they take.
it still takes a little bit if one but its much less than standard extender mode.
Its also why the tri-band extenders work so well. they specifically setup with 1 of the 5ghz bands (higher throughput) for router----extender communication. and that enables the 2.4ghz and other 5ghz radio to communicate faster/lower latency.
JohnDe
Apr 19, 2020Guide
Thanks very much - your explanation was much clearer than support, that totally misunderstood the exact same question. So just to be clear, Fast Lane will always produce a wider faster bandwidth than basic, regardless of 2.4GHz or 5GHz connection? If so, which one is quicker with both all devices and router dual band.
Many thanks.
- JohnDeApr 19, 2020Guide
I meant which Fast Lane Setting: Router>2.4GHz>Extender>5GHz>Devices, or the other way round.
- plemansApr 19, 2020Guru - Experienced User
Again it depends. here's why.
2.4ghz is able to broadcast further and through more materials than 5ghz. But it is significantly slower and more sensitive to interference.
5ghz is much higher throughput but can't broadcast as far or through as much materials.
so in certain instances going router------2.4ghz-----extender-----5ghz-----devices might be faster because the extender is further away or has more materials blocking between router---extender
In other instances, some prefer to go router-------5ghz-----extender-------2.4ghz-------devices. this might work better if for instances you've got a computer hardwired into the extender and want the faster connection to the router and are close enough for a good connection. And/or need the 2.4ghz to reach devices futher away. Take for instance putting a extender at the edge of your home but wanting to reach something outdoors (challenging becaue exteriors walls block more).
That's why its always not a bad idea to try both modes.
As well as try moving the extender around. Sometimes things in the walls (hvac for instance) can be blocking and a lateral move can actually help more than moving closer to the router. Sometimes even moving further can help if it removes that obstruction.
Another thing is because 2.4ghz has less available channels and the extender running off the same channel the router does, trying different channels can reduce interference and let the 2.4ghz operate more effeciently.
So there's lots of optimizing that can be done with extenders.
Thanks once again.
I have it setup at the moment, like this: My internet provider Fibre 50Mb/s download, 10M/bs upload. 5GHz Router channel>Extender EX3700, Fast Lane>2.4GHz to 2 dual band devices 1) ZBook with Intel AC 9560 (1.73GB bandwidth) 2) Roku+ Streaming stick.
I have a strong 5GHz signal strength to the extender @ 768Mbps. So I have no problem with the 5GHz interference.
It doesn't matter with the Roku as I'm only streaming HD at 5m/bs but since the Zbook is limited to a maximum of 300Mbps (I'm getting 144Mbps) Would it be faster the other way round? I can connect to the 5GHz signal from the router directly and even though the signal is a little weak it works OK but strangely with the extender at 2.4GHz it still seems a lot faster.
