tperk
Jul 11, 2021Aspirant
Finding MAC Address
May seem like dumb question but I cannot figure out how to get the MAC address. 2 MAC Addresses on Extender label seem to be for connecting other devices to the extender. I need the mac to connect e...
Jul 12, 2021Guru - Experienced User
Is there any helpful information in the user manual for this?
Does the setup wizard not help you connect the extender to the main host routers wifi?
- tperkJul 12, 2021Aspirant
Yes, but not to find MAC
Yes, I am connected.
Here's my problem. I have about 50 (many no name) devices conected to gateway, including the extender. I simply want to ID the Extender and change its name to "Extender." I am trying to ID all devices to make sure no one unauthorized is "borrowing" my network. It would be easier if the G-1100 has some way to sort or reorder the attached devices.
- FURRYe38Jul 12, 2021Guru - Experienced User
You can look at the sticker on the extender and see the MAC address here. Then look for this address on the main host routers connected clients table...
