tperk
Jul 11, 2021Aspirant
Finding MAC Address
May seem like dumb question but I cannot figure out how to get the MAC address. 2 MAC Addresses on Extender label seem to be for connecting other devices to the extender. I need the mac to connect e...
Jul 12, 2021Guru - Experienced User
Is there any helpful information in the user manual for this?
Does the setup wizard not help you connect the extender to the main host routers wifi?
tperk
Jul 12, 2021Aspirant
Yes, but not to find MAC
Yes, I am connected.
Here's my problem. I have about 50 (many no name) devices conected to gateway, including the extender. I simply want to ID the Extender and change its name to "Extender." I am trying to ID all devices to make sure no one unauthorized is "borrowing" my network. It would be easier if the G-1100 has some way to sort or reorder the attached devices.
- FURRYe38Jul 12, 2021Guru - Experienced User
You can look at the sticker on the extender and see the MAC address here. Then look for this address on the main host routers connected clients table...
