RobbertG
Feb 05, 2024Follower
firmware for X6 AC2200
the light of my X6 AC2200 is flashing green. I want to update the firmware manualy using TFTP.
However I can not find the right firmware in the download centre. Does anybody know which firmware I should used?
1 Reply
1. What device do you have? AC2200 is a speed, not a model. It could be a router, extender, access point. A model number helps.
2. there's several lights on those devices. Which one is it blinking green? Are any of the other led's doing anything? If so, what color and blinking/solid
3. Why do you want to update with tftp? Thats a recovery option if the device's firmware is corrupt of if something fails in the bootup process.
