inbox21
Dec 17, 2021Aspirant
Firmware problems EX6150v2 — AC1200 WiFi Mesh Extender
I had this extender working fine and then after a firware upgrade my IoT video doorbell stoped working for video. I upgraded to the latest version and one change was that it would auto update the...
Dec 18, 2021Guru - Experienced User
What router are you connecting it to?
what firmware version did you install?
Did you set it up using wps or using the installation assistant?
- inbox21Dec 23, 2021Aspirant
I updated it to the latest firmware version via the HTTP interface. It will only suggest the latest version. It has no similar facility for a downgrade.
I set it up using the installation assistant that is entirely local unlike the version of assistant after the firmware upgrade. After the upgrade I "had to" register the device and I "had to" agree to new terms of service just to get into the HTTP config interface.
The wifi router is a ZTE Andriod 6.0 phone.
I had to download a file and go through a manual process to revert the firmware. I didn't recall the original firmware version so I reverted to the first available.
