rlfisher's avatar
rlfisher
Follower
Apr 01, 2018
Firmware update - correct version
I received an email notification of a firmware update for my AC1200/EX6920 range extenders.  However, when I follow the download links, the release notes mention EX6120, but not the 6920.  Can I use ...
  • jvasanth1984's avatar
    Apr 01, 2018
    Hi rlfisher,
                        Package name is EX6920 whereas each unit's model will be EX6120 which you can see on extender itself. Yes, you can upgrade the firmware of EX6120.
