jelrsl
Oct 06, 2020Aspirant
Firmware update fail on EX6200
Hi, I am having trouble with updating the firmware, following the Genie online and also downloading from the Netgear website, both ways fail to update the firmware Hardware Version EX6200 Curre...
Oct 06, 2020Guru - Experienced User
There's a .94 version actually posted now.
When you download the file to manually install it, are you unzipping it?
Some just click on it to open it.
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
jelrsl
Oct 07, 2020Aspirant
thanks for the quick reply, however i tried and it failed
Firmware upgrade failed. Please check your file.
I downloaded and extracted the file to use only the EX6200-V1.0.3.94_1.1.128.chk.
any other suggestions?
- plemansOct 07, 2020Guru - Experienced User
have you tried a factory reset?
Are you on windows or mac?
