Rome0311
Jan 21, 2021Tutor
Firmware Update for AX1800 WiFi Mesh Extender to version 1.0.2.26 from 1.0.1.20
Friends, I got this message from my AX1800 WiFi Mesh Extender: Then I get the below message after clicking Yes. Any ideas why? For completene...
Rome0311
Jan 21, 2021Tutor
Error message
Rome0311
Jan 21, 2021Tutor
Model Info (EAX15)
https://www.netgear.com/home/wifi/range-extenders/eax15
Hope this helps while the moderator clears the pics.
- plemansJan 21, 2021Guru - Experienced User
Prior to uploading the firmware to the extender, did you extract it when downloaded?
How do I manually update the firmware on my NETGEAR WiFi Extender? | Answer | NETGEAR Support
- Rome0311Jan 21, 2021Tutor
To keep it simple I just followed the prompts on the browser interface and iOS app interface. The browser interface gives more interesting feedback - says somethinfg about the file. The iOS app just says it worked and then asks me to re-do the update over and over agian.
When I looked for a downloadable file on the above link it stated that 1.0.1.20 was the current version. So, I was wondering if this was some Netgear mistake or if somebody had any more insight. As the website seems to claim 1.0.2.26 does not exist.
Sometimes the auto-update server gets the update before it gets loaded to the manual update server.
