SherryGPSI
Jan 28, 2021Tutor
Firmware Update has broken my device, support wants to charge me to fix it
We had to reconnect the extender to our Wifi because for some reason AT&T changed the broadcast on our modem. We were able to get it done after resetting to the factory settings and starting over. T...
SherryGPSI
Jan 28, 2021Tutor
I'm a little confused by your reply because I did perform a factory reset, reconfigured the wifi following the APP for Nighthawk on my tablet and the APP went through the Firmware Update steps. So by sitting here following the Nighthawk app you say I'VE corrupted the firmware? Please let me know how that could have occurred. The app indicated when finished that every thing was complete and that a reboot of the device would be automatically accomplished. Following the reboot it has entered its current power light flashing situation. It has never come back on. So please let me know how I have corrupted the firmware by following the app directions and just selecting NEXT, NEXT, NEXT as it went through its machinations?
Given that scenario, you are suggesting that I go thru it all again starting from scratch with another factory reset??
Jan 28, 2021Guru - Experienced User
If you read in the forums, we usually recommend on here to avoid using the app or wireless to update router/extenders. Reason why is when we see corrupt firmware issues, it tends to be when people use the app or over wireless.
If a factory reset gets you back to the power light solid and it booting, then great. Simply reinstall it.
If it doesn't, then try the next steps.
- SherryGPSIJan 28, 2021Tutor
Well unfortunately I did not realize I needed to read about a basic funtion included with the APP in order to complete the process. I am not angry with you. I'm angry with Netgear. The imbecile I spoke with today was useless. There is no way to really contact them when the issue is theirs. I have done the factory reset 3 times now with no change in the state of the device. Any other suggestions since it is impossible to actually get anyone from Netgear to listen?
- plemansJan 28, 2021Guru - Experienced User
Yes, follow the tftp guide or nmrpflash guide.
this allows you to force install the firmware back to it.
