Bob5545
Jul 02, 2023Aspirant
Firmware Update not found!
AC1900 WiFi Range Extender Hardware Version: EX7000 Firmware Version: V1.0.1.104_1.0.184 New update is available. Click here to start It never finds any update?????? Is this the most cur...
- Jul 02, 2023
Bob5545 wrote:
There was no recommendations for updates to my current firmware.
Do you have the firmware updates I need to make this older extender more current.
Maybe my explanation is not clear. Which bit don't you understand?
EX7000 Firmware Version 1.0.1.112 | Answer | NETGEAR Support
michaelkenward
Jul 02, 2023Guru - Experienced User
Bob5545 wrote:
It never finds any update?????? Is this the most current update for this extender?????
If it is, how so I turn off the new update notification????
The on-board check is notoriously unreliable. The best way to check is on the support pages for your product.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
That page will also have any software, firmware and drivers for your device, if they exist.
There have been two new version since yours.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Bob5545
Thanks I did that but it still was not clear what were newer firmware updates.
Thanks
- michaelkenwardJul 02, 2023Guru - Experienced User
