dreamtfk
Jun 24, 2018Tutor
Firmware Update Now Extender Is Broken
Just tried to update firmware on my extender and now it appears to be bricked. Repowering does nothing and the factory reset button does nothing either, it doesn't even reset. I just have a constant ...
dreamtfk
Jun 25, 2018Tutor
Anyone? Looks like this is going into the trash and I will never purchase Netgear again.
DexterJB
Jun 25, 2018NETGEAR Moderator
Hi dreamtfk,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
- dreamtfkJun 25, 2018Tutor
I have replied, thank you.
- ozziatorJun 26, 2018Aspirant
What did they tell you to do? I have the same problem.
- dreamtfkJun 27, 2018Tutor
I received a call from level two tech and it strongly appears that either the firmware update process went sideways or it completed but just didn't play well with the adapter. We tried to connect to it manually via ethernet cable to downgrade the firmware but couldn't get in. They are going to RMA it, this really shouldn't have happened. I have updated firmware before without issue.
- dreamtfkJun 29, 2018Tutor
Dexter, I was under the impression my new unit was already sent but now I am being told by soneone named Eduard that I was supposed to send the old unit first. This is not what I was told on the phone. I was told a prepaid return label would be sent with the new unit. I also provided a credit card number. Can you please straighten this out for me?
