SAG1
Dec 08, 2019Tutor
firmware update option
Is there a way to download a firmware update from my desktop PC to a USB drive and then install it to the extender somehow? I'm having issues logging in to my extender through WiFi. By the way, the e...
Dec 08, 2019Guru - Experienced User
hardwire into the extender using its eithernet port. Then you can update manually. This is the method I recommend for upgrades for everyone.
You do need to login to the extender but when you go to settings----firmare update then you click the browse button and navigate to wherever you downloaded the firmware to. Make sure to extract it after you download it.
- SAG1Dec 09, 2019Tutor
Thanks for the info, however my Windows based tablet doesn't have a cat5 connector. All it has is a micro usb port.
- plemansDec 09, 2019Guru - Experienced UserYou can buy a micro usb to ethernet adapter for pretty cheap. Our borrow a laptop
- FarmgirlchattyJan 14, 2020AspirantHow do you get to settings without being logged in?
- plemansJan 14, 2020Guru - Experienced User
Farmgirlchatty wrote:
How do you get to settings without being logged in?You don't. You have to log into the router to access the settings.
