Srgza
Dec 09, 2012Aspirant
Firmware update WN1000RP
Hi I bought and successfully installed the range extender on my existing network. When I logged into the _EXT router, the first page that came up was an update page asking if I wanted to upgrade th...
s_henrique
Dec 29, 2012Aspirant
I followed exactly the same steps as Srgza and got the same problem.
So far I tried performing the factory reset by holding it longer than 7 seconds with the device on and off, but nothing changes. I keep getting the constant amber status light and no network shows up and no connection happens.
I just got a brick. :mad:
