Srgza
Dec 09, 2012Aspirant
Firmware update WN1000RP
Hi I bought and successfully installed the range extender on my existing network. When I logged into the _EXT router, the first page that came up was an update page asking if I wanted to upgrade th...
tmuilenb
Dec 30, 2012Aspirant
Same situation here, although I had actually gotten everything to work correctly and was playing around with placement. Thought I might as well check for a firmware update and apply it - big mistake. Amber status light and no factory reset - bricked.
Will check back for any status updates while I package it up for return to amazon.
