Srgza
Dec 09, 2012Aspirant
Firmware update WN1000RP
Hi I bought and successfully installed the range extender on my existing network. When I logged into the _EXT router, the first page that came up was an update page asking if I wanted to upgrade th...
jelabarre59
Dec 12, 2014Star
scogie wrote: ...I was informed that doing a firmware update is only recommended if connectivity issues are encountered and also that firmware updates rarely work when done wirelessly..
Considering that the firmware update won't even ***SEE*** the device unless you're connected to it from a wireless device (obviously you can't directly connect to it because it doesn't *HAVE* an ethernet or even USB port), not much other option. Unless they meant that to mean you should never EVER update it, in which case that might be correct. In fact, you should never buy it in the first place.
