thegios
Mar 23, 2023Initiate
Force connection to Mesh Extender
I have a AC2200 Nighthawk X4 WiFi Mesh Extender Model EX7300. The new PC keeps on connecting to the router: is there a way to force the PC to connect to the extender?
Mar 24, 2023Guru - Experienced User
sure there is.
Disable the one wifi (mesh) option and set it with a different ssid.
otherwise its on your device's (computer/phone/etc) own roaming protocol that determine which it connects to
