Aitku
May 21, 2021Aspirant
Force use of 2.4ghz
I am using the EX8000 to reach a summerhouse in the garden some 80 yards away. If my android phone or windows laptop are on 2.4ghz the signal reaches fine. But, they default to connecting using 5ghz a...
- May 21, 2021
Aitku wrote:
I am using the EX8000 to reach a summerhouse in the garden some 80 yards away. If my android phone or windows laptop are on 2.4ghz the signal reaches fine. But, they default to connecting using 5ghz and that doesn't reach yet they don't seem to automatically switch to 2.4ghz. What's the best and easiest way to switch them to 2.4ghz so I get a reliable signal there please?Do I understand correctly that the summerhouse is 80 yards away from the EX8000?
(i.e. the EX8000 is not located in the summerhouse)
My phone often does not switch automatically so I open the phone Network controls, turn WiFi off and back on again, and it connects.
Can you try that?
CrimpOn
May 21, 2021Guru - Experienced User
Can you try that?
Aitku
May 22, 2021Aspirant
Thanks. I've tried switching off and back on the wi-fi on my phone and that does switch it to 2.4ghz. Thanks. Your other comment is right - the AC3000 is at the nearest point in the house and uses the 5ghz backhaul to the main router. I might try moving it to the summerhouse and see whether it can reach the router.
