alitchee
Sep 14, 2015Follower
Found way to connect with http://mywifiext.net/
Hi Found way to connect with mywifiext.net, seems I had some problems with sub web or something well anyway what I did is that I took the web plug way from router/extender and let the cabel between ...
nhann
Sep 15, 2015NETGEAR Employee Retired
Hi alitchee,
Can you please confirm which router and extender you are using?
Once you have downloaded the firmware, you can connect to your Extender's network, then login to mywifiext.net.
Navigate to "Maintenance" then "Firmware upgrade", then upload the file you downloaded.
