Urielp's avatar
Urielp
full wifi frequency range
Hi all,
i orderd this product on Amazon and i faced an issue wth our local telecomunication office.
currently this device will not be released until i will provide the full requency range of the 5GH.
ive been trying to get that information without any luck.
it should say 5.x~5.y or somthing like that.
its very importent that it will be the same product (EX3700-100PES).
can someone guide me how to get this information?
Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    check the channels supported in the GUI. You can then check the freq based on channels supported. We usually support channels 36-48 which is freq 5180-5240 and high channels 149-161 which is freq 5745-5805.
    DarrenM
    • Urielp's avatar
      Urielp
      Thanks,
      unfurtently, our local communication office has confiscated the product.
      the frequency on the high channels are not allowed.
      i had to get approve that it only uses 5180-5240.
      it will detroye if i wont sent it back to Amazon.
