LowellN
Mar 21, 2011Aspirant
FVG318 - Multiple issues
This device has only been serving as a wireless access point connected to our internal LAN through a LAN port, with a static LAN IP and correct subnet mask. It was working up until a few weeks ago...
jmizoguchi
Jul 16, 2011Virtuoso
While looking threw the router I noticed that the date and time are off, to I tried different DST servers with no luck. The router shows -
Current Time: WED DEC 26 12:54:01 GMT-0700 2001
and it is currently -
MON MAR 21 10:13:00 GMT-0700 2011
Does any one have an idea on if these two issues are linked? or a resolution to either.
this NTP sever link up issues. you can try specify different NTP server and see if you can get date updated
