LowellN
Mar 21, 2011Aspirant
FVG318 - Multiple issues
This device has only been serving as a wireless access point connected to our internal LAN through a LAN port, with a static LAN IP and correct subnet mask. It was working up until a few weeks ago...
jmizoguchi
Apr 11, 2012Virtuoso
However, for reasons unclear to me, setting the alternate NTP servers to two from ntp.org didn't resolve the problem for me yesterday. I wonder if the server is actually hard-coded, despite offering the option to input alternate values.
fro the prosafe models that has option to specify other NTP server should work with other than default hard coded NTP server in the firmware.
some unit has telnet capabilities to check as well if NTP are saved on right servers or not
current NTP server is cleared for home end routers so that should go away.
I would put trouble ticket far as putting customize NTP server did not take an effect issues at my.netgear.com
