ctclone3211
Aug 12, 2019Tutor
Get an EXT ending in the Extender SSID
Just installed the Netgear Range Extender EX7300. The WPS was used to connect to my WiFi network. The regular WiFi bands were joined to the Range Extender for both the 2.4 & 5 GHz. The issue is th...
- Aug 15, 2019
Thank you for the manual and the page reference. On my previous EX6150v2 Extender, it was so common to get the EXT extension that when i made the switch and didn't see it, I thought something was missing. Again, many thanks for directing me to the answer.
ctclone3211
Aug 14, 2019Tutor
Thank you for the repjly but when you go through the mywaifiext.net you do not get an opportunity to ask questions only the opportunity to get the extended service package. My simple question is should there always be the _ext at the end. In my case, the SSID was the same as the original 2.4 & 5 GHz. This does not give me the opportunity to know which I am on, even if that is to matter or should it.
Christian_R
Aug 15, 2019NETGEAR Employee Retired
ctclone3211 - There isn't always an _EXT at the end as enabling the One WiFi Name feature allows the extender to have the same SSID and password as the router. However, if you would like to change the SSID of your extender's networks you may refer to page 18 of the user manual linked below.
http://www.downloads.netgear.com/files/GDC/EX7300/EX7300_UM_EN.pdf
~Christian
- ctclone3211Aug 15, 2019Tutor
- Christian_RAug 15, 2019NETGEAR Employee Retired
Hi ctclone3211 - Sure thing! Have a great day!
~Christian
