tonynsx's avatar
tonynsx
Luminary
Oct 19, 2019
Getting money back on broke router
I bought a NETGEAR WiFi router AC1750 from BestBuy about 3 months ago. Today I did a firmware update, and that broke the router. The power light is flashing amber light. I tried resetting and power cycling. I also tried updating the firmware using TFTP but same issue. So I have to get a new router now.
How can I get the money back for this router? I don’t want to replace it. I just want to get my money back.
  • NETGEAR is a crap company. I will never buy their stuff for home or business
  • Not that this matters but I’m in networking field so I did everything I could to troubleshoot. I just want to get my money back since it was Netgear’s own firmware broke it.
    I didn’t register it when I bought it but I can give you the serial number.
    • plemans's avatar
      This is the community forum. Not netgears support site.
      You've got a couple options.
      1. Return it to best buy. Probably your best option if you want your money back.
      2. Actually contact support to see about exchanging/replacing. They can be contacted by clicking the top mynetgear.  You register an account and then the device. From there you can contact support to see what you're options are. I doubt you'll get your $ back but maybe you can exchange it and if you're truly against the product, you can sell it to recoup some of your investment.
      3. Since this is the community forum, maybe we can help. you stated you used tftp. What errors did you get. Where in the process did it fail? Can you take a video of your attempt at fixing it?
      you don't put what model you have. you put ac1750 which is a speed not a model. What firmware version did you update to?
      When you attempted to use tftp, did you enable tftp within windows?
      https://www.thewindowsclub.com/enable-tftp-windows-10
      • plemans's avatar
        Also you posted in the wifi range extender forum. If you'd like help from the community, make sure to figure out which model you have and post in the appropriate forum for you model.
