cfulbright's avatar
Oct 29, 2022
Getting Two Nighthawk EAX80 to Play Nice Together
I bought two Nighthawk EAX80 WiFi mesh extenders a year ago, directly from Netgear, because they supposedly can work meshed.  Of course on day 91, the day after the warranty expired, they stopped playing nicely together.  At least once a week we have to restart one or both to restore WiFi access in the house.
Prior responses here were 1) "get Orbis, they really work"; 2) "your Netgear router is two years old, how do you live with that thing?"; and 3) "disable the mesh".
After putting up with this for nine months, I'm ready to try #3.  How do I change the SSID on one of them so that they stop conflicting?  The Nighthawk app on my phone doesn't seem to give me that ability, or I just can't figure it out.
Thanks in advance for your help.
  • plemans's avatar
    this is how you disable the one wifi feature (mesh).
    How do I enable or disable One WiFi Name on my Nighthawk Mesh WiFi Range Extender? | Answer | NETGEAR Support
    One other thing you can try is making sure the extenders a far enough away from each other.
    Make sure you're setting it up in a star configuration
    star: extender<--------router-------->extender
    If they're daisy chained or to close, they can end up connecting to each other and not back to the main router.
  • Forgive me for being literal, but there is NO "One WiFi Name" radio button.  And I already have different SSID's for the 5GHz and 2.4GHz SSID's on the router and each of the two Nighthawk's, giving me six SSID's.
    I DID disable the "Enable Smart Connect" radio button on both devices.  We'll see if that solves the problem.
