wgrushton
Dec 30, 2011Aspirant
Getting wired/wireless LAN working with 3g Mobile Internet
I'm the proud owner of a Netgear DG834 ADSL Router, a Netgear Wireless Router WPN824, and a Netgear WPN111 Rangemax Wireless USB device.;) I have one Toshiba Laptop running Win7 64bit and a PC running...
jmizoguchi
Dec 30, 2011Virtuoso
Until recently I had ADSL Internet going into the DG834, with an ethernet connection to the WPN824 giving me the option of both wired Lan between the two computers
you had WPN as access point or DG was in modem and WPN was used a router
you have to which way you had
Optus HomeZone box
and you have FEMCELL for your cell phone to use internet for your voice
However, I recently moved home to a location that cannot get an ADSL or Cable Internet connection so my only option is Telstra's 3G Mobile Wireless Internet service.
you purchased MIFI or mobile broadband router unit...
I say you have MIFI
I've been able to get the two PCs talking to the Internet and Tivo talks to the wifi network via the repeater.
if MIFI is repeat capable devices (must support WDS-wireless distribution systems) .
also WPN824 must be V3 to support REPEAT so BOTH much meet the criteria.
DG834 has V1-V5 and all should support WDS so you could use this.
this is how concept works
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
if you MIFI can not have repeat function but existing device can will not work in results EXTENDER is ONLY options.
WN2000rpt, WN3000rp, WNCE2001 of three are choices without doing any of repeating process as extender will going the existing network.
