wgrushton
Dec 30, 2011Aspirant
Getting wired/wireless LAN working with 3g Mobile Internet
I'm the proud owner of a Netgear DG834 ADSL Router, a Netgear Wireless Router WPN824, and a Netgear WPN111 Rangemax Wireless USB device.;) I have one Toshiba Laptop running Win7 64bit and a PC running...
wgrushton
Dec 31, 2011Aspirant
Default Re: Getting wired/wireless LAN working with 3g Mobile Internet
Quote:
P: Until recently I had ADSL Internet going into the DG834, with an ethernet connection to the WPN824 giving me the option of both wired Lan between the two computers
Q: you had WPN as access point or DG was in modem and WPN was used a router you have to which way you had
A: DG was modem and WPN wireless router connected to one port of the DG. Please note WPN is V1.
Quote:
P: Optus HomeZone box
Q: and you have FEMCELL for your cell phone to use internet for your voice
A: It's actually an Alcatel-Lucent 9361 Home Cell 92
Quote:
P: However, I recently moved home to a location that cannot get an ADSL or Cable Internet connection so my only option is Telstra's 3G Mobile Wireless Internet service.
Q: you purchased MIFI or mobile broadband router unit...
I say you have MIFI
A: not sure what MIFI is but the unit does not have a physical connection (eg USB or ethernet) to the laptop and has no ethernet ports. It connects with the laptop by wifi
Quote:
P: I've been able to get the two PCs talking to the Internet and Tivo talks to the wifi network via the repeater.
Q: if MIFI is repeat capable devices (must support WDS-wireless distribution systems) .
A: not sure what you are asking here
Q: also WPN824 must be V3 to support REPEAT so BOTH much meet the criteria.
DG834 has V1-V5 and all should support WDS so you could use this.
this is how concept works
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
A: I've replaced WPN with TotoLink N100R set as repeater and TiVo gets good signal, plus Internet works on both PCs. Internet light is blinking on HomeZone when connected to a LAN port of the N100R, but that's better than I got before but not getting Internet light soild so VOIP not working for mobiles yet. May need a reset at the suppliers end.
if you MIFI can not have repeat function but existing device can will not work in results EXTENDER is ONLY options.
WN2000rpt, WN3000rp, WNCE2001 of three are choices without doing any of repeating process as extender will going the existing network.
A: I'll take a look at these on the Netgear site - Thanks
Not tried LAN/printers again yet - getting close to New Year fireworks here in Melbourne !!:):) Have a Happy New Year :):)
I say you have MIFI
