JL_PN
Dec 21, 2022Follower
Good day my Friends! My EX6110 wont give my PC Internet but it does give it to my Phone.
So the Thing is already tried getting a new Driver. I cleared all the settings on my PC and Repeater and still nothing! Please help
Dec 22, 2022Guru - Experienced User
What router are you connecting it to?
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
schumaku
Dec 25, 2022Guru - Experienced User
Probably not an extender-thing. Once the extender is associated to a wireless access point or wireless router, and the mobile device does connect and associate, you are on the good path. What might be different for the PC with it's wireless adapter is that the additional connection established might require an additional MAC authentication to access the primary wireless network, just as when adding additional wireless clients.
