almaner's avatar
almaner
Follower
Jun 17, 2025
Great choice with the Legion Pro 5
Great choice with the Legion Pro 5—awesome gaming laptop! For a range extender, theNetgear Nighthawk EX7300 is a solid option. It offers good coverage and supports fast speeds with low latency, which is ideal for gaming. Just make sure to place it halfway between your router and gaming setup for the best signal. I’ve had a similar issue while testing out games on pak33 and a stable connection made a huge difference in performance. Hope this helps, and happy gaming!
1 Reply
  • The Netgear EX7300 is a dual band, WiFi5 802.11ac WiFi extender.  If I read the specs correctly, the Legion Pro 5 is equipped with a WiFi6E (802.11ax) adapter.  Since every packet that goes between the home WiFi system and the Legion 5 Pro has to make two "hops", it might result in better performance if the WiFi extender supports 802.11ax.
