nmh1881
Jul 27, 2020Aspirant
GS208v2 and AC750 wifi range extender (EX3700) issues
OK - my set up has been working for years without any issues and over the last 6 months connection has started dropping out and being very unreliable. Running a GS208v2 switch through the wired cat 5...
Jul 27, 2020Guru - Experienced User
so the easy way to test it?
Move the switch and the extender to where the router is. Use 2x known good cables (one to the switch, other to the extender) to connect them. See if it works/stays stable. This prevents issues of wiring within the walls/ends from being the issue.
If it doesn't, then try connecting the extender directly to the router and seeing if the extender stays stable. If it does, its the switch. If it doesn't, its the extender.
the goal is to figure out which one is the issue
- nmh1881Jul 28, 2020Aspirant
Great! Thanks for that. Onto it.
- nmh1881Jul 29, 2020AspirantSeems like switch is ok but extender is again intermittent. Would the fact that I’ve upgraded to fibre optic broadband be relevant? My average seeped is 60mbps now and the EX3700 only accommodates 20mbps??
- plemansJul 29, 2020Guru - Experienced User
nmh1881 wrote:
Seems like switch is ok but extender is again intermittent. Would the fact that I’ve upgraded to fibre optic broadband be relevant? My average seeped is 60mbps now and the EX3700 only accommodates 20mbps??Did you try the extender with it connected directly to the router? And its still intermittent?
A couple things you could try.
1. set the extender with a static ip address within your router
2. reinstall the firmware on the extender (maybe its corrupt), factory reset it, and then reinstall it.
is it only a certain band thats intermittent or do both drop?
The extender is intermitent pulgged directly into the router.
Are there instructions as to how to set a static IP address on the extender?
Do you think the fact my boradband speed is 70 mbps (tested today) and might be too fast for this extender?
Many thanks
