TerryGrant
Aug 13, 2020Aspirant
Guest Network
I have set this up and it extends my main SSID's brilliantly but doesn't pick up my guest SSID's (which is what I really bought it for). Any ideas on how I can fix this please?
- Aug 13, 2020
Run the setup using the installation wizard and select the guest network to extend instead of the primary.
TerryGrant
Thanks. How do I opt to extend the guest network instead?
Aug 13, 2020Guru - Experienced User
- TerryGrantAug 13, 2020Aspirant
Thanks, all good now
