Watcoach
Dec 24, 2020Follower
Had to rename network on Router now how do I rename the network on the EX2700
HI, I had to get my provider to reset my network and needed to rename my network and password. My EX2700 will not connect aoutomatically as it is looking for my old network name. How do I reset it...
Dec 24, 2020Guru - Experienced User
Push and hold reset for 7-15 seconds while the extender is powered on. then follow the installation assistant. I'd recommend the assistant over using the wps method of install. find the guides here:
