JayR01
Apr 18, 2020Aspirant
Half wifi speed via EX3700 than direct wifi
Hi Just purchase WiFi Range extender becasue my desktop does not have a WiFi receiver. Seating in the room where the WiFi Range Extender is connected I get half wifi speed when connected to the e...
- Apr 18, 2020
That's expected. here's the reason why.
Extenders have to recieve a signal and then retransmit it. And it has to do it with the same chip in standard extender mode. This means the bandwidth gets cut in half and the latency is higher than a direct connection.
this can be mitigated somewhat with using fastlane on the dual band extenders or going with a triband extender. Fastlane and tribands reserve a radio just for router---extender communication.
Again, in standard mode, that's how extenders work. They're great for extending distance but they do so at a speed/latency penalty.
Apr 18, 2020Guru - Experienced User
- JayR01Apr 19, 2020AspirantThx.
Luckily it does not affect me much as I only need it to connect my desktop. But if i wanted to improve the speed on wifi should i set fast lane to receive on 5Ghz and emit on 2.4Ghz?
Best
J- plemansApr 19, 2020Guru - Experienced User
Try both routes and see which works better. Its pretty easy to swap which one acts as backhaul and fronthaul.
